Suspension is compatible with the 05-09's, 2011 had a few minor (but significant enough to warrant their own aftermarket parts) tweaks in the front suspension, the rear is the same though. The front suspension in 2010 has beefier spindles (as used in all 2011+ cars as well) with the new fine thread strut to spindle bolts, same lower control arm and ball joints IIRC. The strut body and shaft is the same as the 05-09's though. In 2011 they changed the strut mount tops to suck less... they succeeded in making them suck less, but they still suck!
The Charge Motion plates are built into the intake manifold. To delete them (common mod for the 1/4 milers) you either get plugs welded in the holes from deleting them or you get an 05-08 Intake Manifold and delete plates or you replace the entire intake manifold with one from the aftermarket that does not have the Charge Motion Plates. Spark plugs are different after 09 as well but that's been covered.
Ohh, yes, ugly taillights, I have a cure that makes them better looking:
Tint those suckers, and I mean the reverse lights, heavily, but leave the reds lighter. Looks so much better than stock!
