I am new to the forum and forums in general, so I apologize if I totally missed similar questions in my searches.
I just bought an 08 with an installed boost bros turbo setup. From a couple of threads I read, there was a love/hate relationship with boost bros. I have a couple of questions:
1) I am assuming that other turbo setups are similar in the pipe fitting which maybe required some modification to the stock front bumper for it to all fit. This one was modified, but kind of looks like crap right now. I am wondering if someone else found an aftermarket that fit better?
2) What kind of fans are you using? This has a single 12" puller that wasn't working (I discovered after overheating twice) and had to do a field job hard wire. Need to replace for the obvious reason of it being too small for the setup up, but not sure what the best fitting system would be.
3) I am getting an excessive amount of heat coming in through the shifter/e-brake area? I'm not sure if I need to look into adding heat-shield or something, or what the best option would be there. With my last mustang (06 gt - stock engine aftermarket intake and axle back exhaust) I did have increased heat from total stock, but not quite to this extent. I have only had it for 5 days so, haven't had a chance to put it up and look at the cats when hot. My hunch is that it is a combo of the fan being too small, and not enough heat escaping so it is being forced up into the cabin.
4) When the engine is cold, do you get some lag when accelerating?
Thanks - trying to get to know this thing. It is my first turbo set up.
