What power adder are you planning on using.
The stock Cobra crank is fine if you will be using turbos.
But if you will be driving a blower off of it that is where the stock crank can be a failure point. The stock 03 Cobra crank has an undercut on the snout where it should be solid and even have a radius. The snout has been known to break off, destroying the engine. Generally when you are running a bigger crank pulley and a huge blower. If running the stock pulley support with bearing none have failed.
So keep that in mind when making your decision.
There is a "bandaid" fix to help save the snout. Have the hole in the end of the crank drilled so it goes almost all the way back to the first bearing journal and run an ARP stud instead of a bolt. That will put the clamping force into compression instead of tension. And possibly save a snout that is borderline.
Here is a discussion about the crank fixes from Modfords. It includes the engineering drawings and a discussion about billet cranks too.
Oops. Since this is my first post I can't include a link. I will make another post directly below this on with the link.
---------- Post added at 11:26 AM ---------- Previous post was at 11:25 AM ----------
Here is the link to the crank shaft stud and snout problems and fixes.
Stock lower pulley cage with crank anchor stud mod....
