gears q?
1.4K views 13 replies 7 participants last post by  ChrisJ
#1 ·
hey i definately want to do 355 gears on my 92 but what all would i need i know the ring and pinion but would i need a new posi and how hard is it to install the gears i installed a new clutch so i think i can do it but i dont know anyone who has done them
#2 ·
I would recommend replacing all the bearings and seals as well. While installing gears isn't rocket science, the proper setup is very important to ensure a successful job. Also, some special tools are required to do it and unless you plan on doing a lot of them, it isn't cost-effective to buy them just to do 1 set of gears.
#6 ·
I would say go with 3.73's...Go ahead and replace all the bearings in the rear; You will already have access to them all so just put all new ones in for sake of mind...I would also recommend paying someone to install them...Gears can be tricky and they need to be set up right or it will be all kinds of badtimes...
#8 ·
$370 in parts:
$200 for gears (give or take): $100 for install kit (give or take): axle bearings, seals, oil= $70
Labor is going to vary by vicinity. Twist 2 go can give you what an honest and fair install rate should be
#12 ·
stang fanatic said:
$370 in parts:
FRPP gears can be found for around $170 & $100 for the install kit. Axle bearings around $50-60. The gear oil depending on which brand you get anywhere from $3/qt to $15+/qt.
Labor prices vary widely due to location, overhead, etc.... The shops here in town get $275-$400 but I don't have the "overhead" they do, and do them for $150-$175. (Now you see why some of the shop owners hate me :D )
#14 ·
notsoslo5.0 said:
thanks a lot guys i sure wish i had someone like twist 2 go here in ilinois
From what I hear he is "THE MAN" when it comes to gear install...
