Alright, I have been shopping around for a new motor ( something stroked ). Would you guys go for this 347 for just over $2k?
Seasoned 302 Hydraulic Roller Core Block
Oven Baked
Shotblasted (Remove scale, rust)
Magnafluxed for cracks
Cylinders bored on Kwik-Way Boring Bar and Table
Finish honed on Peterson Powerstroke Hone with BHJ Aluminum Torque Plates, Fel Pro Head Gaskets and ARP Hardware (.0001-0002 Taper MAX)
Plateau Brushed (Provides Instant Ring Seal)
Main Bearing Bores Align Honed on a Sunnen CH-100 Hone
Deck surfaced on a Winona Van Norman CBN surfacer (Ra Finish compatible with MLS Gaskets)
Screw In Oil Galley Plugs
Lifter Valley Oil Drain Backs Chamferred
Oil Filter Inlet Chaferred
Threaded Holes Chased
Lifter Bores Honed
Crankshaft Balancing done on Hines Dominator XP Digital Balancer (.02 Grams)
Scat 9000 Cast Steel 3.400 Crankshaft
Scat 4340 Forged I-Beam Connecting Rods with ARP 8740 Capscrews and Full Floating Pin End
Probe SRS 2618 Forged Aluminum Flat Top Pistons (10.5:1CR, Inline or TFS Valve Reliefs, Your Choice. Dish and Dome Pistons Available, SAME Price, you choose)
Clevite 77 Main Bearings
Clevite77 Rod Bearings
Clevite77 Camshaft Bearings
Perfect Circle Moly File Fit Rings (Gapped Specifically for your application)
Fel-Pro 1 Piece Rear Main Seal
ARP Main Studs with Oil Pump Pickup Provision
Deep Seated Freeze Plugs
Camshaft Retainer Plate
Painted ANY Color of your choice, just let us know
Then which of these options do you recomend?
28oz Harmonic Balancer 69.00:
Billet Steel Flywheel 99.99:
SFI Flexplate 49.99:
H-Beam Rod Upgrade 150.00:
Probe Main Girdle 129.99:
28oz SFI Balancer 169.99:
4340 Steel Crank 300.00:
Early Casting block 68-75 100.00:
Thanks for the input guys....
Oven Baked
Lifter Bores Honed
