As of right now, I am taking an automotive vocational class, it's hands on which is plus.
Long story short, I asked the instructor could we swap out a Chrysler 318 for a Ford 460 (both are on stands).
So after trouble shooting all hands pointed at the ignition.
Like a dummy, I pulled all the spark plug wires :facepalm: to test spark and now I do not know which wire goes to which cylinder.
I think this is the firing order is.
1-5-4-2-6-3-7-8
So how do I put each spark plug wire to the correct cylinder so it ignites with the firing order?
Also how do I set base timing as well? I cranked cylinder #1 with a breaker bar to TDC and and the rotor was off :headscratcher:.
I'm guessing the rotor is supposed to be on cylinder #1 when near TDC right?
So I rotated the distributor cap to try to get the rotor to fire on cylinder #1, I thought the rotor was supposed to be directly on spark plug #1. There was too much obstruction.
I think I REALLY screwed up the timing, I really have no idea what to do at this point.
I want to get this engine up and running. Any ideas on what to do?
1-5-4-2-6-3-7-8
