Well, last weekend I went ahead and replaced my intake manifold with the newer Ford Racing intake manifold with the aluminum crossover. The install went great, went to start it up, kinda died on me the first few tries, than it finally kicked over, idled fine and has been driving ok ever since. It is failry slugish throughout the power band, especially if I have the AC on. At idle its fine, but coming out of idle is sputters just a tiny bit.
Like I said, drives fine, oil pressure is fine. No leaks, no loss of volts or anything out of the ordinary.
My best guess is one of the spark plugs have gone bad. I honestly have no idea how a bad spark plug will sound or perform. I suspect this only because a little bit of coolant got to one it the top of the plugs where the COP plugs in. I tried to soak up as much as possible, but their was just a little bit still chillin there.
Now, I called a mustang shop, and they said that they suspect I may have dropped something in the heads, and its just knocking around in there. I told them maybe, but don't think its the case since it drives fine and its more of a constant ticking that increases with the RPM's. It never goes away.
Ideas?
Ideas?
