Not sure if you guys are versed on the MAF conversion, but here is a write up.
Mustang Mass Air Conversion StangNet
The 87 harness color is not the same apparently as the 88 as in his write up. I got the whole thing done except for the VSS signals. Do you guys know what colors I need to tap into for that? Everything I have read is DG/W and O/Y wires, but this car nor the other 87 I have does not have these wires. I have two options on the VSS so If worst comes to worst, I will figure it out by trial and error, but I would rather not.
Here is my harness options.
Under the car.
ON the kick panel
Thanks guys
Under the car.
ON the kick panel
Thanks guys
