New Edge autocross set up
20K views 25 replies 9 participants last post by  EscortSportage
#1 ·
So I have been to a couple of autocross events this summer, and have been enjoying them.
I don't really expect to be super competitive, and the car sees a lot of street miles still. But wondering what people are running setup wise?
My car seems to have a lot of body roll in the front end still, and has a tendency to understeer.
Here is my suspension set-up.
Front:
Stock v6 front sway bar (1" diameter)
energy suspension poly sway bar bushings
energy suspension offset steering rack bushings
energy suspension sway bar end links
UPR tubular front k-member and a-arms
front strut tower brace
MM CC plates
MM coilovers with bilstein front struts, 200x12" springs, car is setup pretty low
255/40/17 nitto nt555 tires
Rear:
tubular upper/lower control arms, poly bushings, not sure what brand
GT take off rear sway bar
315/35/17 nt555
MM XL full length subframe connectors
KYB GR2 shocks
eibach prokit springs
anyone have any advice?
I don't plan on going to a panhard setup or anything, too much money for my taste, for a car that is going to be autocrossed a few times a year.
Braking wise, I have stock calipers, powerstop pads and rotors, and I just ordered new stainless steel brake hoses.
#3 ·
Not an expert on the SN95, but a 255 front and a 315 rear is a pretty extreme stagger that would cause the rear end to have a lot more grip than the front. All the fast autox guys I know, and in particular one well set up new edge Cobra on slicks, runs a square tire setup. Even the national level S550 guys in Street class, which requires us to run stock width wheels, run square tires despite having wider rear wheels. Now I'm no SN95 expert, but I'm assuming the MM shocks up front have a lot more damping than the meh GR2s in the rear, and if the front compression is much higher, when the weight transfers to the side of the car on turn in, the front end will tend to wash out since the rear will load up first and dig in.
Finally, the roll you're feeling is cause the 200# front springs are relatively soft compared to the 500#+ springs others like Whiskey seem to be running. I'll wait for him to chime in on spring rates, but it is possible to run more than 200# up front and still maintain a decent street ride while having a well balanced and fun to drive autox car. Hope this helps, but going to a square tire would make the biggest difference.
Guess he did chime in right as I was making my post - go Whiskey!
#4 ·
I emailed jack at mm to see what he has to say.
I wonder what a 250-12 or 300-12 would ride like on the street?
I also think a larger rear seat bar may help aide the car from pushing in the corners with the staggered tire set up.
Or I should just buy another set of wheels for autox, lol
#5 ·
If the dampers can handle the springs, it'll firm but not harsh. IE: All the chassis movements go straight into the body of the occupants, but that movement is far less harsh than even an OEM setup with lowering springs. I daily drove my S197 with 550lbs/in front springs and 275lbs/in rear springs. It was firm, but not harsh. Eschantra can confirm it did handle well too! :)
Thing is, the SN95 front suspension geometry is awful. The rear suspension geometry, is also quite awful. Try and find iRoush's Youtube videos of the front suspension. He was running like 400lbs/in front springs on his MM coilovers and it looked like he was running stock springs there was so much movement of the LCA. All that movement on a strut suspension is bad, to an extent. 400lbs/in would be a starting point for me.
Hell, on my S550 (when it arrives) when I go to coilovers I'll probably go back to 550lbs/in front springs and whatever it takes to balance those front springs out back. Smallest rear bar possible.
#6 ·
Agreed. Definitely stiffen up the spring rates. and get the tires square. most people I see on street tires are running 275's on all fours. stupid newbie me only bought 265's
I put on the H&R Super Race springs and was worried about a harsh ride but it was actually a lot better then worn out soft stock springs. firm not harsh. I drive mine on the rode a lot too.
#8 ·
I'm running 12" 200 lb. springs in the front of my car as well. Just keep in mind, if you increase the wheel rate in the front, then you would also need to increase the wheel rate in the rear to maintain level ride. Jack @ MM reccomended I install MM Torque Arm springs in the rear if I wanted to go with stiffer rates in the front.
#12 ·
I've been upgrading my '04 GT DD for autocrossing and I've learned a bunch from the MM guys. Springs and tires is covered well in comments above but there a couple things that jump out for me.
1.) Poly bushings in a tubular UCAs is a problem. Unless you go Torque Arm and remove the UCAs the bushings and arms need to be complaint enough to compensate for the binding in the crap four link rear end. Could even damage the chassis mounting points with significant body roll.
2.) Last upgrade on my car was the MM Panhard Bar. Really improved the behavior of the back end for both street and track. UCAs don't take lateral loads any more. Fairly big project but if you've done the front cross member install it should be no big deal.
Lastly I'm currently working on something nobody I could find makes for our cars. Sold bearing style front sway bar links. The urethane donuts in the stock links have to compress by design before fully loading the sway bar. I designed spherical bearing rod end (Heim Joint) links for my 1970 Mustang when I first got into autocrossing so I'm doing it again for my '04. Less body roll and better transient response. All the later Mustangs appear to have some kind of solid bearing style links as part of Ford design upgrades. But the rod ends look way more cool anyway. I'll take pics when its done. :)
#16 ·
With coilovers in the rear? 550lbs/in up front and probably 225/250 out back would be at the upper end of what I'd consider for a street driven car with a serious emphasis on autocross duty. If you were in the stock location out back, I'd say stiffer, but with coilovers you gain a lot of motion ratio and don't need as much spring rate. Up front, you have to remember you are fighting some really "awesome" geometry from Ford with regards to camber curve and if I'm at 550 on an S197, I can only imagine 550 is going to probably still not be enough to get the front tires happy enough! :)
#18 ·
You know what will be an awesome set up - SLA type in front (e.g. from Griggs racing) and IRS from S550 in rear. Now that will be a real sports car. Will not need stupid spring rates or ridiculous size tires. Technically you can do that if you have money.
#20 ·
I like to do auto-x myself. Run pretty well in my group with NASA (usually top 3) and I could probably pull off 1st every week if I had a manual trans.
Currently I am running the Eibach Pro-street Coil-overs and Eibach 35mm swaybar in the front and 24mm rear. I get compliments about how neutral the car is. I also run a "square" tire setup. Nitto NT05 275/40/17s all the way around. Cobra swapped brakes and Hawk HP+ pads. The car will push in a corner if I brake too late but otherwise it ain't bad. Keep in mind though my engine is mostly stock compared to yours.
#21 ·
Any idea what the spring rates are that come with the eibach coilovers are ?
Edit: actually nvm. AM lists them as 200 front 250 rear. Which is odd, usually the front has a higher rate.
But then again it looks like the eibach kit isn't a true coilover as it looks like it uses an adjustable perch in the stock location. Am I correct ?
And here is my wheel rate math
Currently my setup is 180# and about 157# rear (that is at ful load though as those are progressive springs)
#22 ·
I honestly couldn't tell you. It isn't compressed so to speak like in a car that came with a coilover setup. You can safely disassemble the entire setup without any special tools. There rear is still a spring and strut setup though with that kit. Idk if you can really get a true coil-over setup for our cars but KW offers a pretty good setup but you will spend a lot of money for it.
I don't know if the spring rate is correct but I imagine the big sway bar helps too.
