Hey guys,
Trying to track down something I've noticed recently which is excessive white smoke out of the exhaust. While it doesn't smell sweet and I don't see the coolant levels dropped, I was chasing other possibilities. I went to change my PCV valve, which I am assuming the previous owner didn't change, and I saw excessive amounts of oil on the connector neck for the tube that goes into the upper plenum. The tube was also filled with oil as well. From what I've read, this can indicate excessive blow by and a bad PCV correct? The old valve rattled. So my question is, is this normal? Was my PCV valve? Should I get an oil catch can? And what would cause the excessive oil? The below picture sucks, but the connector to the tube is drenched in oil while the part that goes into the valve covers was clean and free of oil...
As far as catch cans go, where is a good place to get a decently priced one?
