After changing my UCA and mount I noticed an increased whine from the rear end at steady highway speed. I first wrote it off as increased noise transmission thru the UCA, but it started to make me nervous so I checked the rear end fluid and found it is down 2" from the fill hole. I had gears installed 2 years and not even 10K miles ago. I never checked the fluid level after the gear install. I would like to change to Royal Purple. Question, can I just drain the existing fluid from the drain hole and ad the Royal Purple, or do I need to remove the cover and get all the old stuff out before adding the new stuff?
Thanks
Thanks
