I installed an AOD transmission to my 1990 Ford mustang with a 5.0l v-8. The torque converter was rebuilt as long as the transmission at the same place. Well I installed everything but the speedometer cable because I haven't ran the new cable. So after taking the car off the jack stands I put ATF in the fill tube and ran the car switching the through the gears ( I did put a quart of atf in the torque converter before installing it) And it still won't move.. it seems as if the transmission fluid isn't being pumped because the fill tube stick looks as if the transmission fluid is just sitting in the fill tube... is there anything I could do to figure this out? Could it be the transmission lines because I didn't replace them? Could it be the torque converter?.... Everything is practically new and I have a lot of time into this project... very frustrated
