I think you would be making a mistake to install the rods and crank from one block into another block without first doing some machine work.
Even though the parts are metal they still shift, distort and change in shape with use over the years and miles of service.
Even the slightest change of shape and fit of the parts can cause you to destroy your new engine.
You should always keep the block, crank and rods together as a unit if you are not going to do basic machine work to make sure that all the parts are true.
If you are gonna mix and match blocks, cranks, and rods then you should at least hone or bore the block WITH a deck plate, re-size the rods and turn the rod and main journals of the crank, taking off just enough to make sure the crank journals are true and round.
You should also check the main saddles of the block to make sure that they are still true.
I don't mean to be rude or anything but to be honest if you are mixing and matching parts from multiple blocks and you are not aware of the things you need to do in regards to machine work to make them work together, then you should probably leave all the parts with a good machine shop, allow them to do the needed machine work AND let them build the short block so they can be sure that all the parts are true and within specs and tolerances.
