Seeking some advice regarding issues I've experienced with a JLT Carbon Fiber Cold Air Intake and Bama 93 Octane Race tune ordered together from AmericanMuscle.com.
After installing the intake and uploading the tune I noticed that my car felt a little weaker than normal and was idling a little rough. I took it to my local dyno shop and after a few runs saw that the car is putting down 325hp and 322ft/lbs to the rear wheels with an A/F ratio of 15.08. Note, this is less than a stock 5.0 automatic running 87 octane puts down (my car is a 6spd running 93).
The car was also showing the typical trouble symptoms of a JLT CAI. It was surging while cruising on the highway and throttle application in 6th was extremely jarring.
I called Bama and they said to log some different driving scenario's on my Diablosport inTune tuner and to send these back to them ASAP so that they could write a new tune (which I did).
After sending in the logs I received a response saying that my tuner did not pick up the parameters that they needed. They suggested resetting the tuner to factory defaults and going out to log some more data.
Before I did so, I made the following adjustments after doing some research online:
1) Moved the JLT air filter further away from the MAF
2) Removed factory sound tube and capped off openings
3) Removed factory rubber spacer between MAF and intake tube
4) Let the car idle for 5 min until it reached normal operating temps. Then I let it idle for another min with the AC on. Then proceeded to drive for a few miles.
This seemed to make things worse. After logging data by:
1) Cruising at 1500,2500,3500,4500 rpm for 15 seconds each
2) Doing a 2000-5500 rpm WOT pull in 4th
3) Idle
the car threw a check engine light and then started sputtering and violently shaking. It wouldn't rev past 1500rpm and then when I pulled it over to the side of the road it stalled.
I was able to clear the check engine light with the Diablosport and drove home just fine but I am starting to get extremely worried.
Bama claims that the carbon intakes are not made uniformly and therefore a tune that works for one will not necessarily work for another. But should it really be this bad?
I'm wondering if anyone else has experienced these problems with a similar set up?
At this point I'm considering having my buddy trailer the car to my dyno shop and have them write a custom tune for it and ask AmericanMuscle for a full refund.
I can upload pics of how the intake looks (air filter relative to MAF, rubber spacer, etc...) if any of you think that will help point out the issue but I'm really worried truth be told.
I just can't believe that AmericanMuscle/Bama would sell a product that they don't fully understand. Imagine if I hadn't gotten the car dyno'd and drove around ignorantly thinking it was fine. At an A/F of 15.08 I could do some damage to the internals, no?
3) Idle
