Smog Pump Eliminator
3.5K views 12 replies 9 participants last post by  95StangSVT
#1 ·
the guy before me out a shorter belt to bypass the somg pump but the belt was makin sounds and everything was not turning the right way so i put the long one on to work everything and now the somg pump making sounds should i get a new one or just get the Smog Pump Eliminator thanks
#8 ·
I am also hearing some noises from the smog pump on my 95 GT after replacing the belt. Before it was a little squeeking that would stop after the engine got warm. Now it sounds like theres something scraping or rubbing on the inside. The noise didn't start when I first put the belt on, it started a few days later. I saw where one guy gutted the smog pump and now his acceleration is not hesitant and reving from idle it sounds great. I'm not sure how true this is but what is the purpose of the smog pump and does it have anything to do with passing or failing emissions?
#12 ·
its making that noise cause there are bearings and veins inside that are going bad.
#13 ·
eleminator
Go with the eleminator pulley because when i by passed the smog pump and put a shorter belt on mine it started making my tensioner swing wide open to were it would make a slap sound,i tryed diffrent belts and sizes and a new tensioner but it still did it so i went out and bought the eliminator pulley and put the stock belt back on and had no problems sence....
