It seems like the 4 cylinder struts might be too soft on the compression rate for a 5.0 equipped Mustang.In otherwords they might be ok for front end lift of the car(when you launch)but I think you might encounter the suspension dropping too hard once the front end settles back down and the struts compress.4 cylinder struts are designed to control the weight of a 4 cylinder vs a 8 cylinder.They're a little more expensive,but adjustable struts would be the way to go on your setup.4 cylinder springs do work great for drag racing and the front end will also get lowered about 1/2-3/4" due to the additional weight of the v8 engine.The rear won't get lowered at all from the 4 cylinder springs unless the rear springs are the ones you said had a half coil cut out of them.If the car is gonna be stricly for drag racing only,the installation of 90/10 70/30 front and 50/50 rear Lakewood struts and shocks would work well,but I wouldn't use them on a daily driver/weekend racer Mustang because they're not meant for street duty or corner carving.You want the rear shock to compress(car squats down)as much as possible,the front strut to easily rebound(extend)during launch,but when the front end drops back down you wanna have quite a bit of compression (strut will be stiffer and have more resistance to it so the front of the vehicle doesn't slam down hard on the pavement)If you've ever driven a classic car on the interstate with worn out shocks,that's the same type of feeling the front end of your car will have when the front end comes back down after launching,if you run a strut with too soft of a compression setting.You want the strut to be somewhat stiff so the tires will be on the surface of the road just enough to maintain control.If the compression setting is too soft,the whole weight of the front end and motor basically digs into the pavement(figure of speech)and that's extra resistance that slows the car down.Just like if you run wide tires on the front vs skinny ones.The skinny tires creates less resistance and that equals faster et's.You might experiment with running the stock 4 cylinder shocks on the rear just to see how much squat they allow until you buy better shocks.If you run the 4 cylinder struts on the front and the car is a daily driver,I'm pretty sure the car is gonna ride fairly rough since theyre not designed to handle that extra engine weight.Curves might be a little scary to
ne trick that will help you with launching is to remove the front swaybar or at least remove the swaybar endlinks while racing.Reinstall them before getting on the street though because the car will lean badly around curves without the swaybar.You can also buy a adjustable pinion snubber to mount between the differential case and underbody.The factory one is tall and won't allow the rearend to squat as much so you can get a couple more inches of space if you swap the snubber out.
