Thermostat question???
659 views 4 replies 4 participants last post by  BUGMAN
#1 ·
hey everyone its kind of a simple question but does the thermostat have a gasket that is needed? I mean beside the black O-ring. Ford said no but I have coolant coming out the thermostat area and were the hose meets the thermostat. If it does not need a gasket, I am alittle worried I may have a crack in the upper intake. But not sure yet. The other day I had white smoke coming out of the exhaust so I am also worried about water going where it shouldnt be going.
Thanks for the help
Vince
#4 ·
wow no kidding I am having the same problem. So your saying to be mind full of getting it in there straight b/c sometimes they do not sit right? I thought it was like a drop in and close up kind of deal. I would love for this to be the fix I am looking for. I have coolant coming from where the flanges meet and it appears to have some coming from the bottom of the upper radiator hose but maybe it just looks that way.
If there is anything specific you did please let me know. I would love to have this problem go away.
Vince
#5 ·
What he is saying is very common because the thermostat sits sideways. When you put it together if the thermostat itself slides down just a tad it will create a gap and cause it to leak. I have seen this more times that I can count especially on the 5.0 motors.
Just make sure that the thermostat doesn't slide down. If it does it will leak but look sealed after tightened up.
