TR3650 TSB's
2 reading
7.6K views 16 replies 5 participants last post by  Lefty
#1 ·
does anyone know if any of the tsb's had a part number for steel shift forks and which one had the part numbers for the different detent springs and balls?
#4 ·
technical service bulletin. tge detent springs and balls help control how much effert it takes to shift into gear. i think the ones in the tsb are a lighter spring
#5 ·
TSB is technical service bulletin. Not sure which one you want:
15175
2001 Mustang - T-3650 Transmission shift fork bending
Some 2001 V-8 Mustangs equipped with TR-3650 transmissions built from Feb-2001 to Aug 2001 may exhibit difficulty engaging 1st or 2nd gear. This may be due to an out-of-spec 1-2 shift fork. A new shift fork has been developed to service this condition (2r3z-7230-aa). Remove transmission and follow service procedures detailed in 308-03c for dissassembly and assembly of replacement 1-2 shift fork. Examine 1-2 syncronizer and blocking rings for any damage. Service as necessary following service procedures in 308-03c.
http://www.allfordmustangs.com/forums/attachments/4-6l-tech/10505d1124891875-tr3650-tsb_3650_1.jpg
http://www.allfordmustangs.com/forums/attachments/4-6l-tech/10506d1124891887-tr3650-tsb_3650_2.jpg
Another version:
http://www.stangnet.com/images/stories/docs/sn95_TSBs/04-15-06.pdf
#7 ·
Hmm...I could have sworn the bent shift fork TSB didn't apply to the 3650's. I know there's on for the T-45 1st/2nd gear shiftfork. I can look tomorrow on AllData if you still need specifics or anything.
#8 ·
the 3650s had them to lefty, but what i find it was on the early 01 models. So I think I already have the redesigned shift forks.
#9 ·
I can double check on Ford OASIS for you if you give me your vin.
#10 ·
I dont have my vin on me. I know I have some of my old fellow workers at the local ford dealership looking things up for me also. The TSB pertains to 01-04 models thats why I was wondering. I dont need the syncros or blockers since I am doing something custom, Its just if the new shift forks were beefier than mine, I want to change them
#11 ·
:lol Yeah I don't blame ya. At least the 3650 and the 45 are easy as **** to rebuild (or tear apart for that matter and put it back together). So you'll have no worries workin' on it if you do decide to swap internal parts.
#12 ·
shes already apart and syncros and blockers already modified ;) along with the sliders. It wont be very street friendly to the average person if you know what i mean lol
#14 ·
Have to double clutch to down shift
#15 ·
There's nothin' wrong with that. Do it all the time on old tractors and **** when I'm runnin' around on my Aunt & Uncles farm.
