so im supposed to be getting some pi heads pretty soon. i did plan on putting just some stock pi cams in em but then i got to thinking that maybe i should put some comp cams in. wut kind of cams do you guys think i should get?
I personally think that 270's are a little bit much to use for a street car. Is this your daily driver? If so i'd go with a little bit of a milder cam. And make sure you get it tuned.ive heard to get 270s. wut can u tell me about those? and would they be good?
Thats exactly why i wouldn't use them for my DD.270s seem like a 3k to 6500 rpm camshaft... it will be a slug under the power band.
When my PI motor ran, it had no problems under 3500, but once it hit at 3500 it hit and it ran well. It was almost like the nitrous was hitting in on this NPI motor...270s seem like a 3k to 6500 rpm camshaft... it will be a slug under the power band.
thought u had a custom grindWhen my PI motor ran, it had no problems under 3500, but once it hit at 3500 it hit and it ran well. It was almost like the nitrous was hitting in on this NPI motor...
do u still have the heads from that motor?it technically was, but it was a comp 270 with the advance out of it. SO a staright up 270, the grind i wanted was going to cause me to do fly cuts, and To properly do that IMO is to take the pistons out, whcih i didnt want to do at that time.
hey man just go to there web site and look at the tech number and give them a call. Thats what i did. i just ordered my 268s about a month ago.can someone post a link to the 268 comp cams becuase i cant seem to find em?
