Status
Not open for further replies.
5,401 - 5,420 of 19,030 Posts
Mines the same. But I never got axles so it wasn't a big deal. And I run 1.5" spacers in the back to compensate.
i was going to run 3/4" spacers
will it be fine without spacers until i can get some?
Save
i also have a 99-04 panhard bar to install, i wonder if it will fit now. ahhhh and now i have to buy wheel spacers, this really sucks
Save
I dont see why not, as long as nothing is Rubbing?
well MM sells two different ones, one for 98 and earlier mustangs and one for 99-04. I sent them an email to see if they know. Maybe i will just sell it
now i have to go buy some new drill bits because i dont have a 14mm one to drill the holes out.
Save
Some Plastic from an old remote, a couple allen head screws, a dremmel, old 3 way switch found in garage, and a small piece of shrink tubing, i did what the stereo shop said wouldn't werk!!! and looks half way decent, way cheaper than a 125.00 replacement from ford!!!
What is the switch for?
8.8 is mostly in
whats the red bar?
I wish that too. But luckily I can just do mine at work after hours. :D
ahhh lucky S.O.B :llama
Save
Got the Passenger side Outer Tie Rod Done.
Taking a Break because I Pinched the **** out of my Finger. :D
Other then that, I Got it done pretty easily.. Couldnt BUDGE the Nut on the back, So I made sure my New Tie Rods were the same exact length, And Put it where it was. Tightened everything up, Torqued it to what the book said, Sat her down; No more wheel Wobble.. Glad its done, One to go. :D
ordered wheel spacers and new axles
having a hell of a time finding a 14mm drill bit thought
Mr Red pony, did you use a 14mm or a 9/16" bit when you drilled the holes out?
Save
For the LCAs? I used the biggest one I had (3/8) and walked it around until the hole was big enough. Try a uni-bit. (the tapered one that steps up until the bolt just fits.
Save
I talked to the Midas guy about welding Dual Exhaust.
He said if I were to cut the old Muffler off myself, And Cut the Pipes at the cat's, welding new mufflers in would only cost about 50$ with New Hangers.
I'm planning on doing it cheap.
Glasspacks. :D
Any Recomendation's on glasspacks?
Save
Agreed glass packs=nasty. found that mac flopaths are one of the better sounding mufflers and decently cheap. :new member by the way(first post ha):
Just put H&r SS springs and left off the iso today no more rock crawling for me :(
Save
Status
