161 - 180 of 216 Posts
Discussion starter · #166 ·
Why wouldn't the flywheel bolt up to the TQ Converter ? Bc It has 8 holes In the flywheel instead of 4 wth?I need to swap flywheel but I can only put 4 bolts in tbe flywheel not 6 im getting depression bc of this **** man. Could it be that I need do line it up correctly so flywheel have to be put on a certain way?
Sent from AutoGuide.com App
Flywheels are for clutches, flexplates are for torque convertors
---------- Post added at 12:46 AM ---------- Previous post was at 12:44 AM ----------
There's only one way a flywheel or flexplate will bolt to the crank
The cranks come in both 6bolt and 8 bolt patterns. U gotta have the same number of bolt holes on the flywheel/flexplate too. N if they still don't line up, just keep rotating the flywheel, n it will line up with all holes eventually.
Nice build BTW!
Discussion starter · #170 ·
So I mounted the tanny to it and will weld the egr tube from the headers shut so I be sure it wont leak from there
---------- Post added at 09:13 PM ---------- Previous post was at 09:09 PM ----------
I will put it in Wednesday and Thursday and Friday and sat will be the small stuff and turning that sucker on!
Discussion starter · #173 ·
Today's progress. I cant put the steering shaft in its in a tight place going to have to pull the steering shaft from the inside to make it go back some and be able to pull it back then foward into the space in between the headers.
Discussion starter · #174 ·
I need help the flexplate wont move and the starter is not on. When I placed the tranny and engine together i was able to rotate the crank now one that the engine is in the car it won't !
Did you fully seat the TQ converter on the transmission before coupling the motor to it?
If your certain you coupled them properly dont sweat it. you should be able to turn it over with a pry bar. if not remove the plugs to releive some compession then try it again.
Discussion starter · #178 ·
Turn it over with a pry bar?
