I told myself I'm going to sell the car if I had one more alternator go on it. Should I? I can't afford this **** anymore. It wasn't even at high rpm or anything.
I already checked all the grounds and replaced the engine to chassis ground with 4 gauge wire.. I just can't figure it out for the life of meShitty ground somewhere?
2 of them were high output alternators, 3 were from autozone and 3 from Fordwhere are you getting these alt's from? i went through 3 in one year from carquest! So i finally went to the shop down the road from me and he said they were made shitty something to do with the stator plate i think its supposed to be welded with a bead all the way around, and anymore they just tack weld them. A lot of them are made cheap and refurbished, and when they get hot they crack and don't charge, i had him order me a new one made in USA and it's been fine for 1.5 years now, dammit i wished you lived here so i could take you to john and get your **** tested![]()
If it's bad wiring then why doesn't it immediately fry the alternator? It always takes it at least like a week before it dies. Which wires are you talking about? There's only one wire going to alternator and it's connected directly to the battery. Then there is the plug with 2 wires going to it.damn hardhitter. I hate hearing that bro. There is some bad wiring somewhere! If i were you i would find someone with the same car and be sure of EVERYTHING. Match up all the wires and so forth to be sure they are all the same i guess. :dunno
Bout to PM you...
