Spool and install ?
11K views 9 replies 5 participants last post by  limited
#1 ·
okay over the weekend i broke my auburn pro series diff which i had my whole end set up with 31 spline axles. my question is if i alrdy have the carier shimmed and set perfectly from the previous install can i just drop teh carier and toss in the spool and bolt it all back up and be done ? and will a spool break on me i have full drag suspension and 410 hp 411 tq ?
#2 ·
I would have a professional do it right. You also would have to have c-clip eliminators installed on the axles. The axle tube has to be machined in order for the new eliminators to fit. At that point you should have the axle tubes welded.
#6 ·
To get rid of the c-clips you only need the c-clip eliminators pressed on the axles and the axle ends machined to accept them...It's not cheap to have done. I have it done..
Now you can be cheap and get an open diff for 31 spline axles and put a mini spool in it that accepts c-clips. I ran one in my 8.8 before switching to the spool. I ran my best et's with a mini spool.
#8 ·
you won't have to reshim if you use same carrier/gears and install a mini spool.
Why anyone would run a spool on the street is beyond me, very hard on tires/axles on turns. if you drive on street and want spool like performance on the track,get a detroit locker. They do make a ratcheting noise on turns but is much easier on the rear end in general, or a arb locker would be nice if they handle the power
