Supercharger
1.9K views 20 replies 11 participants last post by  Tang Stang
#1 ·
Does any one know where to get a whipple supercharger kit? I see the upgrade kits all the time for the cobras. But I want a kit for my GT.
#2 ·
Could be wrong, but I believe you need the Tork Tech adapter kit or something to throw a Whipple on a 2V. But a Whippled 2V would be badass
#9 ·
#13 ·
Nice blanket statement that's not particularly accurate! That Kenne Bell in the video is an old 2.2 unit supplied by Autorotor, which did have oil and seal issues. Autorotor is no longer in business, and Kenne Bell no longer offers a 2.2, as they brought their designs in-house with the new generation of Big Bore units.
#12 ·
Yeah, you want to get their "Cobra upper kit" which is the one that doesn't come with the supercharger and whatnot. Then you just have to get a 03/04 Cobra spec Whipple of your choice. (If your drivetrain/engine/fuel system is build to high heaven, 3.4 Crusher :drool)
Although if your bottom end isn't built, why not pick up a 4v C-head motor like a 99/01 Cobra, Aviator or Marauder for less than $2k and it will bolt right up anyways? You might save a few bucks and put down more power. :shiftyeyes
#20 ·
and every combo has its pro's and con's which can be addressed somewhere else down the line threw drive train.
There's something people fail to comprehend.
will a whipple fit under a stock factory GT hood on the 2V?
Since you'd have to use the tork tech adapter- no. The tork tech adapter even with the M112 requires some cutting and a larger scoop. For some reason the freakin scoop is $280 IIRC.
You can go several routes, new hood of the design of your choosing, or big aftermarket scoop/cowl on your hood.
