Trying to clean up my engine bay...
15K views 36 replies 19 participants last post by  302Army187
#1 ·
'85 GT, carbed. All the vacuum lines, a/c lines, wiring, etc etc are stock.
Main questions:
What can I get rid of on the firewall (wiring and such)?
What smog equipment/lines can I toss?
Whats some other stuff under the hood I can toss?
I dont care about passing smog, not a concern. Some pics of clean engine
bays would be sweet, too :cool:
Thanks.
#2 ·
get rid of ALL the emissions junk, tuck your coil, and other wires on the driver side in the fender, and move the battery to the truck.
there is a guy called "AmostStock" on another forum that went nuts hiding wires, and showing you how to do it. he showed with his dash removed he routed the main harness wiring that is on the firewall into the car itself, behind the dash, to hide it.
here is a crappy picture of my engine bay. No a/c, emissions, and a little bit of wire hidiing. alternator hung low to get it a little more out of sight, and show off the heads.
#3 ·
if you want to search for what was mentioned above the guys screen name is "almoststock" and look over on corral.net
allot of people start by pulling the smog stuff ie egr, egr solenoid, tad/tab, heat pipes to the rear of each cylinder head, and all associated vacuum lines. Delete the smog pump and run a smaller serp belt.
Most people eventually move the starter solenoid from the driver side fender to inside the fender and out of sight but some wires may need to be lengthened
#10 ·
I love your engine bay, that so clean.:cool: i wish i could do some thing like that but im in california so all my smog equipment has to stay:sorry
#25 ·
The easiest way to put it is, off everything that is not needed to run the car and the accesories your going to keep. Everything else can go. That means battery in trunk vacume tree, wiper motor, AC if you dont need it, smog and all emissions crap. cruise control, ect ect. move the rad overflow, fuse box.
#33 ·
Thanks TKOTLARZ
95opal,
Did you take pics throughout the process??
I just tore my 95 appart thanks to a minor lil'accident and while its apart im going to do some cleanup and cleanout!!!! got lots of questions for you and where you place things and how you did some stuff.
Also, where did you get that upper radiator hose?? that thing looks sick!!!!
I do have some pics of the process and I will help you in anyway I can. The rad hoses are from Mac if i recall. I did modify them a bit and used some other hardware to achieve the look. PM me your questions and ill see what I can do to help ya.
#30 ·
95opal,
#37 ·
What intake manifold is this?
I recently bought my car which has the same intake.
Thanks
it is a professional products typhoon intake.
