my MACs cleared the starter pretty well. my problem was the frame on the passenger side. turned out that when i dropped my motor back onto the mounts, it was misaligned slightly to the pass. side.
OP, i would first check to make sure your motor is lined up straight. then i would put the car on a lift and go over those headers with a fine tooth comb. make sure there's at least a 1/4" clearance along all the runners. in my experience, JBAs are notorious for rubbing the steering linkage. maybe whoever did your headers laid the motor down a lil to the pass. side to avoid this. if so, either remove your steering linkange and grind a lil off where it rubs, or dent the exhaust runner that hits the linkage.
(oh, and keep in mind that JBA will void your warranty on those headers if you dent them. but its funny because they recommend denting them to clear the steering linkage. that right there says something about that company)
