What problem would lean out a F/I tune w/ no changes?
2.1K views 30 replies 16 participants last post by  jkolbfleisch
#1 ·
So my car was running 11.5-11.8 A/F @ WOT perfectly for weeks ... but sometime in the last 2 weeks, it has leaned out to a steady 12.3-12.6 A/F @ WOT throughout the ENTIRE RPM range. That makes me pretty nervous to run hard and I wanted to hit the dragway this weekend. NO changes have been made since the tune except I pulled all the intercooler piping off and reclamped in same positions.
I have:
- Replaced Fuel Filter
- Datalogged FPDC .... never over 85%
- Re-Calibrated my Wideband O2
- No CEL codes
Could adjusting the Intercooler piping have shifted the MAF readings that much? Could a boost leak make it go LEAN instead of rich? :screwy:
#3 ·
All the pieces and couplers are in the same location. I'm sure there was a tiny bit of shifting around with the adjustable slack in the couplers ... but still in the passenger fender well with same bends before and after.
#4 ·
Hmmm that seems odd, what side is your wideband on? Drivers or passenger? I would pull all those plugs on that side make sure they look okay.
Maybe the sensor itself is bad?
#5 ·
I think 12.3-12.6 AFR seems pretty good. You're still a bit off of stoich. What are you worried about. Also, you said you recalibrated your wideband... maybe nothing has changed, just the number you're seeing.
#11 ·
Clean the maf and connections. Make sure its clocked the same as it was before. Clocking the maf can have a HUGE impact on the tune.
#13 ·
I'm positive I must've rotated the MAF Housing but at this point I have no clue what it's original position was. Do you just suggest rotating it 90 degrees, testing and retesting?
My wideband still reads 14.6/14.7 @ idle so it seems like it's reading right ... but I suppose I can find someone else with a wideband to test. If it means anything, I'm running an almost new Innovate Digital MTX.
#12 ·
12.8 is pretty lean for a FI car. Its like saying "she only has a little herpes"
12.5 is ehhhh
From my experiances and from what iv seen. Aftermarket wideband sensors are normally junk.
Iv seen them as far off as 1.0 which can be life or death at times.
Maybe its your sensor. Anyone you know have a spare wideband to stick in it and verify.
#16 ·
There is not a real tuner in this country that will tune a pump gas boosted car to mid 12 afr at WOT. Everyone must be crazy when they say take your foot off when you see the wideband go into 12 at WOT.
#18 ·
Did you have a boost leak when it was tuned? If you adjusted the fittings and now have no leaks it can lean you out, but if you still have the same amount of boost that would not be the problem. Just throwing some more ideas out there.
#19 ·
Hahaha. I thought that'd throw you off a bit. It was in my fathers experimental aircraft. Believe it or not, there's about 10 airplanes flying around with my enignes in them... somewhere. I lost track of most of my customers when I got out of that business. They were cool, but dangerous.
#20 ·
You dont remember which direction you had to plug and unplug the maf from? Come on THINK HARDER. If not then you could try rotating the maf 90 degrees at a time and see if it richens up a little... If you clocked the maf that is probably the problem. I'm guessing your running a LMAF in a blow through app? or Some sort of standard housing maf in a blow through app? Either way draw though and especially blow through, changing the maf clocking can affect the AFR. Obviously its going to read normal during regular driving because its in closed loop... but I bet the fuel trims are further off than normal.
#22 ·
Reason I'm nothinking it's fuel delivery is the A/F goes to 12.5 immediately once WOT. So even @ 3500RPM flat through 7000. Bad pumps would just start to lean out at upper RPMS. Plus my fuel pressure and pump duty cycle both look normal.
Boost Leaks ... while I can't say I had 100% no leaks during tune ... my Boost gauage shows aboutt he same psi. (It's hard to tell if I picked up an extra 1psi due to the gauge's range)
I'm gonna take the advice put out earlier in the thread and try fiddling a little bit with the MAF rotation today. See if that helps any.
#28 ·
I wouldn't trust it, especially with 10:1 compression ratio. Try reclocking the MAF a little at a time.
#31 ·
This got brought back up but I'll update it for future searchers. I forgot that I had relocated the IAT sensor from pre-blower to POST-blower. It was enough of a difference to throw it all off. I have since gotten a new tune and it was sitting pretty since.
