I'd ditch the lightning MAF and use the stocker+Mafia in a blow through set-up. Only thing good about the LMAF is it's calibrated for 42's. The 4inch meter in 3 inch tubing kills the range on it anyway and makes tuning a bitch. The L is good when used for draw though.
So I should be fine just using the same hole that the current bypass valve uses and just weld in the alum flange of the tial 50mm and vent it to atmosphere? then just plug up the hole in the filter housing where the bypass output was?
