Status
Not open for further replies.
18,541 - 18,560 of 19,030 Posts
Also just scored this for 50 bucks shipped
my stocker is falling apart and im starting to hate how spongy our sixxer steering wheels are
Save
Just meticulously washed my car, buying the meguires paint restoration kit tomorrow for a real shine, exhaust video also coming tomorrow :p
Sent from my PC36100 using AutoGuide.Com Free App
You need more than that for a real shine ;) Get the mothers clay kit and cleaners wax instead, you will have a better result
Just found out that my brakes have been slightly dragging after purging air from the brake lines. Well ain't that a .....
Been hurting... They've been dragging all this time. I've never bled the brakes since I've bought the car. :facepalm:
You know what that means...
You sir just contradicted yourself
Save
stupid stock clutch started slipping so bad i cant drive the car
any reccomendations for a clutch to support over 400rwhp?
and should i bother with an aluminmum flywheel while im in there?
Save
When you bleed the brakes you also purge out the air. It goes one with another... Where's the contradiction?
Exactly my point, u claimed that ur breaks are dragging when u purged the air out the lines, then you claimed u never did it... Ergo contradiction....so which is it?
Save
RAM or Spec may have a stage 3 clutch for our cars, couple other may as well however never looked into it. From what I've heard an aluminum fly wheel may or may not be worth it, similar to UDP's, if you have the extra cash I'd say go for it
Save
??? Ok I'm going to say this again with more detail.
After purging/bleeding my brakes, I've noticed significantly less drag on acceleration and coasting. Especially on first gear, where I used to feel a killer drag (i made a post about this). Because of this change in behavior after purging/bleeding the brakes I'm led to assume that my brakes have been dragging all this time.
Edit: I see where you might have missread. I meant that I found out about the issue after purging the air out, not having the issue after purging the brakes.
Save
:lmao
Save
Uhh question while were on the topic of brakes. When I push the brake pedal down it creaks. Does that indicate air in the brake lines?
No that just indicates that your break pedal creaks. prob at the hinge.
Sent from my droid using my fingers.
  • Like
Reactions: GreenShift
Save
Status
